Opinions please...
SchnozzSchnozz Frets: 1948
edited November 2018 in Guitar
I'm thinking about pimping my superstrat up a bit with some blue pickups, knobs and a switch tip, but I'm in a bit of a dilemma about the electronics.
I'm happy with the Seymour Duncan 59/JB combo, but other contenders include the Dimarzio Air Norton/Tone Zone combo, or Alegree Heat Waves and all of them provide powder blue bobbins (I think).
I was also thinking of the multi-coloured Jason Becker set, but I'm not sure how easy it is to get someone to route for a middle S cleanly - Would someone need to use the original pickguard as a stencil for an entirely new pickguard?
What's your thoughts?
https://i.imgur.com/M0JnQen.jpg
https://www.youtube.com/watch?v=57E-dUPuMzg
  • SchnozzSchnozz Frets: 1948
    I love Seymour Duncans, but I'd appreciate them more without that damn logo.
  • FunkfingersFunkfingers Frets: 14430
    Take a look under the pickguard. The G&L body might already be routed HSH. If so, you just need a replacement pickguard.
    Which begs the question, why change them? If you just want a splash of colour, consider bobbin toppers.
    It might be simpler to change to a five-way Superswitch and mimic the DiMarzio/Ibanez circuit that yields;
    Bridge HB, Inside Coils, Bridge HB + Neck HB, Neck HB with its coils in parallel, Neck HB.
    Cheers Funkfingers,
    It's definitely routed for HSH and the coil split works well, so it's more for aesthetic purposes - What's a bobbin topper? You can remove the top plastic? s
    Interesting! Thank you
  • ICBMICBM Frets: 72352
    Easily removed in two minutes with some T-Cut.
    Personally, I think the guitar looks great as it is - apart from the Duncan logos - and I wouldn't change anything else.
  • TenebrousTenebrous Frets: 1332
    If you just want to spruce up the colour scheme of the pickups while covering the SD logo, there's this great Japanese company that @skullfunkerry recommended for my RG: https://www.inlaystickers.com/collections/6-pickups-decal
    Came within the week, well packaged & ready to go. Yet to put em on yet as the strings are still new(ish), but hey, it's something that might be worth considering.
    They look good as well - What's the difference between F-spaced and normal spacing? (You can tell I mod nothing)
    Will give the T-cut a go as well!!
    The F-spaced ones are ever so slightly bigger. They've very detailed diagrams on the website so you can measure exactly what you have, but chances are they'll be F-spaced.
    They came really quickly! Looking forward to seeing them when they're on :)
