Nobels ODR-1?
If so yeah great, big fat OD that can make a single coil bridge sing. Great pedal....
Build quality isn’t as good as some pedals but there are a few boutique makers who have pedals based on the same circuit.
I wanted a pedal which I could dial in to sound like the amp itself, then add some gain and it works with any clean amp, not just Blackface types.
There’s also a notorious fault with some early ones, which is caused by a bit of bad PCB etching and makes them self-oscillate when the level is turned right down - but not in a good way.
