It’s not an issue with the amp because it’s increased by the Tube Screamer, so it’s noise being picked up by the guitar.
It’s nothing to do with the tremolo circuit, because the Princeton uses bias modulation tremolo rather than an opto-coupler, which is the type that’s been replaced with a new circuit.
Try unplugging it if so.
Anyway, about five minutes earlier, my cordless phone handset started beeping. I took it out of the cradle, thinking It wasn’t connecting to the charging contacts. Took the nicad AAAs out, put it back again, still beeping. It was making funny electrical noises when I held it to my ear. As I was doing this I could hear similar electrical noise coming from the hi-fi speaker (amp was still on, but no music playing). I’m sure there was some serious disruption to the mains supply to most of the street.
By taking out one of those wifi electrical internet mains boosters has helped alot on this test. I still get some static noise from the pedal but goes if i rest my barefoot on the pedal? lol
Also I noticed with ts on cranked loud if i turn a light on and off in a diff room i hear the reverb on my amp make a pop sound?
If not, the earth connection to the strings (via the tremolo claw in a Strat with a trem) is missing in your guitar... when you touch the footswitch with your bare foot you're grounding yourself, which should also happen when you're touching the strings.
It’s worth trying the amp at a different location.
The other thing to discount might be the pedal power supply, but either way I’d mess with those two variables. These amps are usually pretty quiet and the symptoms do point to external interference.
My Princeton picks up significant external interference, usually after 9pm, I can often hear a noise like ‘turn it down, the kids are in bed....and you’re banging your foot again’.
Only seems to happen at my house so I assume It’s local interference.....
