I just got a new pair - £45 from Asda Opticians, including coatings.
I now have 2 pairs of glasses: 1 pair for general use, which are varifocals, and another pair specifically for computer use & reading. This second pair are apparently called "occupational glasses" and are effectively bifocals, although without the line in the middle.
The reason I have 2 pairs is that although the varifocals can work for reading or computer use, they're only correct in a very narrow range of the lens. Since I spend pretty much my entire day using a computer for work, the second pair is much more usable for this, because they give the correct focus for about an arm's length away and slightly closer, across a much wider range of the lens.
I'm long sighted (I'm 54) with a very mild prescription for distance and found standard varifocals awful for computer work.
It would be a perfect anti theft device, and you could make them bifocal so old people could still stare at the end of their own bonnet.
Otherwise I find I’m tilting my head to look through the bottom of the varifocals.
The contact lenses don't work in the same way as the glasses. With the glasses it's all about which part of the lens you're looking through - basically straight ahead or down. The contact lenses have different "power" at different parts of the lens, almost like the rings on a target, and your eye just adapts to seeing through the right part of the lens. Or something. I think it depends how wide your pupil is, they don't work as well in dim light.
Neither of them are perfect though. I can see fine for distance, looking at a computer screen or reading a book, but they don't work for all distances. I still can't focus on anything really close up without taking off my glasses.
They're good for driving though, as I can see the dash and other vehicles. Which is nice.
