It it's arriving between 14:00 and 15:00, should we expect a classifieds listing between 16:00 and 17:00 (allowing for an hour of head scratching) :-)
They're actually fairly easy to get your head round, even I managed it for a while, so enjoy bud, the sounds are very good on most things
Feedback can be found here http://www.thefretboard.co.uk/discussion/comment/908933#Comment_908933
Easy enough to get into though, and a superb device
Just put together something basic yourself straight off.
For sale yet? ;-)
Hope you're enjoying it
You may have more success with Jason Sadites... Although I’m not sure he’s done much for the HXFX.
My advice would be to recreate your most recent incarnation of your regular pedalboard bit by bit.
Or (assuming you're using it with an amp) try a few of the basic drives in turn, have a run through the reverbs and delays, all that sort of thing. It does an awful lot of stuff!
Not for sale yet!
Had a quick run through the presets, which as I expected are all a bit over the top, but shows huge potential....
Have had to stop and find a tutorial as I couldn't even work out how to bypass it to just the amp, or how to create a patch, or set a unity level, so now will rewatch all the YouTube vids again to refresh my memory as I've got a bit overwhelmed.....
Later I'll try amd create something simple, then build on it...shame I don't have a board for reference to copy!!
Hey-ho, onward and upward, how difficult can it be?
Put in two tremolo blocks, both tap tempo, but one at half the speed of the other and lower depth.
This gives a lovely wub-WUB-wub-WUB effect that works at any speed you like.
Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
Small steps..
I wish I could block delete all the factory presets....
To be fair though in a few minutes Ive pretty much got the hang of the basics, its now just a matter of getting more adventurous
It really is easy to use if you start with a blank preset too... remember, all of the Helix vids are largely applicable to all models. Maybe watch the Helix Floor/LT vids too, to give you an insight.
For example,
