New body or old guitar?....
I want to upgrade my 90s Squire Tele. The way I see it is I can either use the neck and drop it on a solid wood body with some SOL67 Oil City pickups I’ve had my eye on and a new harness OR buy a pre owned MIM Tele, swap out the pickups and sell the Squire.
I figure the cost will be much the same at the end but what will be the best end result?
  • sweepysweepy Frets: 4184
    Get the MIM Tele, the neck is much nicer and you are starting from a better modding platform
    Depends how much you like the Squier neck.....but as above a used MIM is prbably a better bet....
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    There may be little difference between the two guitars, realistically.
    A well dressed neck, nut and setup will work wonders.
  • ICBMICBM Frets: 72394
    If you love the neck on the Squier, replace the body. If you don't, replace the whole thing.
  • John_PJohn_P Frets: 2750
    I’d agree - a well set up Squier and a MiM aren’t a world apart imo, if you’re going to upgrade and want to do it with parts then gradually add them piece at a time. You could get the pickups now and swap them back if you decide to sell the Squier later.
  • And I guess if I ever want to sell it a mim is worth double what a Squire is
  • FunkfingersFunkfingers Frets: 14446
    This is why I own several Squier Vintage Modified series bass guitars and exactly zero Fender MIM ones.
    This is true at any price point. IMO, with the right fettling and a few well-chosen component upgrades, the Squier makes its nearest equivalent Fender MIM model look over-priced.
