Adding an external speaker jack to a combo amp
Hi,
I have a Marshall Lead 12 Combo amp and I want to add a speaker out so I can connect it to an external cab. Just so I dont blow it up, does anyone have a quick guide to doing such a mod?
I have read that I just need to cut the cable from the amp into the speaker and add a jack on the amp side and a plug on the speaker side. Does that sound right?
  • ecc83ecc83 Frets: 1638
    edited April 2014
    ICBM will surely have the full SP but personally I would leave well alone.
    The internal speaker is 8Ohms and a Celestion G10, not a bad model? The danger is an external feed could get shorted and the schematic shows no protection AFAICS.
    The circuit also uses a current feedback trick to simulate the higher OP Z of a valve PA abd this might be a problem if the speaker lead is long enough. The circuit also uses the horrid jack switching technique to get a headphone output. This is a known source of trouble, if not in this, in other transistor amps.
    Dave.
  • ICBMICBM Frets: 72486
    edited April 2014
    I've fitted these with speaker jacks in the past. The amp section is identical to the head version they made for the original micro-stack. There may not be any proper protection, but actually these are the most robust 12W solid-state amps ever built - at least that I've ever seen or heard of - and I doubt there's any risk.
    The way I've done them is simply to ream out the cable hole in the chassis floor and fit a jack - make sure it's the plastic insulated type like the ones on the front panel, so it doesn't couple the ground to the chassis - with a plug on the cable.
    This is what the chassis looks like inside - I've seen less beefy 100W amps!
    And yes, the combined headphone/line-out jack is a nasty solution and sounds crap for headphones anyway, so I would probably bypass the switch in it and make it line-out only.
    Said Eee'd know!  I only had the schematic.
    Yes, that looks pretty chunky, should blow the fuse first. Would that ALL transistor amps were such a BSH grade!
    Dave
    Exactly. This whole series are possibly the very best solid-state amps ever in terms of build quality - basically identical to the JCM800 valve amps, but with transistors. Full welded heavy-gauge steel chassis, ply cabinets, decent speakers, overspec'ed internal components… they also sound great, are loud for their rated power and almost bombproof.
    Sadly, I expect they would be thought of as uneconomical to make by modern standards, given some of the cheap crap Marshall have turned out over the last few years.
  • funstuiefunstuie Frets: 77
    what sort of jack should I look for? When I search on ebay I get thousands of options.
    oh and thanks for the responses.
    I want the Lead 100 MOSFET head.  SO BAD.
    This one:
    http://www.hotroxuk.com/mono-input-jack-4-solder-terminals-switched.html
    Connect the wires to the terminals on the side you can't see in this pic, black closest to the nut.
    edited April 2014
    I found this on another forum. Is this correct:
    No, because that's for a jack which switches to the external speaker while still leaving the internal one hardwired.
    It's much simpler just to use a plain jack with the internal speaker plugged into it.
    All you need to do is connect the wires inside the amp to the two terminals on the right in the lower pic, then put a plug on the wires to the speaker with the red going to the tip (centre) connection. If you cut the existing wires at the cable hole they will be the right length.
    OK Thanks for the clarification.
    All ordered.
  • AlanPAlanP Frets: 54
    Dave.
    Hmmm... If that's the schematic labelled 3005.gif, I can't see any unusual "current feedback trick" - it looks bog-standard to me (albeit using darlingtons)...  but no protection though...
