Helix HX - Silly Question.
jimkehoejimkehoe Frets: 208
edited December 2018 in FX
With the exception of the Stomp I have had every variant of Helix.
I currently have a Helix HX effects which I love and is brilliant for my needs into an amp.
However I am in the process of (another!) gear evaluation/swap round and one of the options is some sort of interface/amp emulation to use between the Helix HX and a PA speaker and/or monitor speaker?
I know I am likely to be inundated with obvious replies of "get the Stomp" etc but was wondering if there is another solution?
  • siremoonsiremoon Frets: 1524
    Joyo American Sound is not bad and fairly cheap.
    “He is like a man with a fork in a world of soup.” - Noel Gallagher
  • Various ways you could do it but I would suggest getting an amp in the box type pedal and run it into an IR in the HX. Lack of volume from the pedal obviously won't be a problem as you can boost it. Something like a Wampler Black 65 or Plexidrive would be perfect.
  • jimkehoejimkehoe Frets: 208
    Will check it out. Thanks.
    Thanks - amp in box pedal into HX rather than the other way round?
    Pedal into one of the loops so you can position it. Definitely needs to go before the IR.
    Brilliant Thanks @rossyamaha ;
  • SporkySporky Frets: 28370
    I liked the speaker emulation on the Award Session JD10.
    Also on the Behringer GI400.
    Thanks @ Sporky. Must ay from You tube and Google the Joyo American sound is looking a great solution especially for the price.
