What finish over Satin Urethane?
I have a Squier Bullet neck which is whiter than my legs, so am thinking of putting a vintage finish over it. What would be the best product to use to refinish a satin urethane neck?
  • munckeemunckee Frets: 12400
    On my squier standard I used Osmo Poly tints, a whole can is expensive but you can get tester sachets on amazon for a couple of quid, each sachet does a coat.  I used 0000 wire first then applied with a cloth and used the wire again in case of any areas with more finish, 3 coats I think.
    Cheers Munckee I'll take a look.
