White-ish dust/powder in guitar?
markvmarkv Frets: 459
I've just noticed a white-ish/beige powder inside my guitar. I can see it on the top's bracing and on the side. The photo below shows it on the treble side of the inside of the top bout, but there's more in the corresponding position on the bass side. It's dry and comes off if wiped. There's a bit of a musty smell in the guitar maybe, or maybe I'm imagining it. It's not strong, if it is there.
Any thoughts about what might this be, what might be causing it and what would be a good way of removing and preventing recurrence, if such a treatment is needed?
The guitar is a Morris, made in Korea and bought new about 20 years ago from Ivor Mairants - not particularly valuable but I like it
I've had a search on the internet and of course there are many, many answers. :pensive:
Thanks for any help!
https://i.imgur.com/t7W05vS.jpg
  • StrangefanStrangefan Frets: 5844
    Cocaine  . Definately cocaine.
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • octatonicoctatonic Frets: 33796
    It is usually polishing compound from manufacturing.
  • FunkfingersFunkfingers Frets: 14424
    Its favourite habitat is machinehead holes through headstocks.
  • p90foolp90fool Frets: 31589
    That looks like mould.
  • markvmarkv Frets: 459
    Thanks for the answers so far.
    Yes, that was my concern, but I didn't want to jump to conclusions. Unfortunately I don't remember seeing it before ... which could mean it's only recently appeared, or it's always been there and I am just very unobservant, or have a bad memory, either of which could well be true.
  • ICBMICBM Frets: 72325
    It's polishing compound residue - very common on cheaper guitars where they don't block the soundhole when buffing the guitar. You might not have noticed it before because it's in a place you rarely see unless you're looking on purpose.
    They use a big buffing wheel and it flings off the compound sideways as it passes over the soundhole. You can see how it's been thrown against the side wall of the guitar and the brace has left a 'shadow' and caught some of it.
    Aha thanks guys - that's set my mind at rest!
  • FelineGuitarsFelineGuitars Frets: 11594
    If there is a musty smell don't overlook mold - like mildew
    Wipe down with a little diluted bleach on a cloth
  • do you use a plectrum?
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
    good point - if it were under the strings I'd have suggested ground fingernails
    Online I've seen about 50% people recommending this, and 50% people saying "omg don't let bleach anywhere near your guitar!" ;-) So good to have a recommendation from someone who knows what they're talking about, thanks! I assume you mean inside the guitar?
    Yes, most of the time.
    have you tried hydrogen peroxide n lemon juice as an alternative bleaching agent ?
    To remove all doubt you could just taste it, it'll taste like mouldy bread.
    It might clear up that embarrassing itch, too. :)
  • proggyproggy Frets: 5835
    That could be woodworm.
