F#minor
TedTed Frets: 126
Is this difficult or what?
I am playing it the 'easy way' with the first finger barring the first three strings on the second fret and the third finger on the fourth string of the fourth fret.
Trouble is it seems to be a hit or miss affair whether I play it properly and at the moment i can't do at anything like 3 second intervals I need.
I really like the chord and it fits in well with a tune I wrote so need to persist but any advice appreciated.
  • monquixotemonquixote Frets: 17609
    It's the sadest of the keys.
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • PhiltrePhiltre Frets: 4173
    Can you play the full barre version and just strum/pick the strings you need?
    Did you mean "sadistic"?
  • mgawmgaw Frets: 5262
    practice practice practice, just stick at it mate, every thing gets easier as you progress frustrating at first but once the strength builds up in your hand and muscle memory takes hold you will scoff at F#m
  • It's the sadest of the keys.
    I always thought F minor was more sad
    soundcloud.com/thecolourbox-1
  • TedTed Frets: 126
    Ok - I think i might I have nailed it, I suffer from the 'collapsed hand' syndrome which you can get away with on most main chords but not,it seems, this one. With the thumb acting as part of a pincer on the back of the neck the chord becomes much more possible.
  • Alternatively tune down a semi tone and play G minor ;)
    Strictly speaking it should be d minor, but I can't resist a spinal tap reference.
    I suppose A Flat Minor is more sad for their family members
    A Flat Minor Diminished for the smaller family members.
  • bigjonbigjon Frets: 680
    A lot of the time this easy-to-play F#m7add11/C# sounds just as good in context - x44200
    Or you can wrap your thumb over the neck and play 244200, a full-sounding F#m7add11 chord
    As heard in Had Enough by Mr Big, or Mandela Day by Simple Minds, which I discussed in my chord--of-the-week thread on open-position F#m chords at
    http://www.thefretboard.co.uk/discussion/15928/chord-of-the-week-10-5-14-f-m
  • ToneControlToneControl Frets: 11896
  • sev112sev112 Frets: 2764
    Stick a capo on the second fret and play Eminor instead :)
    then D becomes C, Em becomes Dm, G to F, etc
    all easy peasy now :)
  • The best fix is to master using barre chords.  Both 6th string root and 5th string root, then you'll be able to G#m, G#Major, C#m etc, etc,.    It can take a few months but how old will you be in a few months if you don't learn them?  A good practice bit is the verse from Bob Dylans "Lay Lady Lay", all full barre chords, "A" 5th fret, "C#m" 4th fret, "G"  3rd fret, "Bm" 2nd fret.
    Or just don’t use chords that involve more than 4 strings
    there is no rule that says you have to play all 6 strings
    and therein lies a root to why so many people give up guitar in the first year
    we should just teach them 3 and 4 string chords
  • Use a capo ;)
  • octatonicoctatonic Frets: 33797
    Don't use a capo.
    Do consider having a lesson with someone who has good technique and make sure you aren't doing something counterproductive.
    And that's presumably why so many acoustic buskers bash out full six string chords all the damn time as well
  • RolandRoland Frets: 8704
    This. A and E shapes are the most common, followed by C. G and D shapes are possible, although I don’t find much use for their voicings.
    Some chords are easier to play thumb-over, some are easier with a full barre. You need to be able to play both ways. A couple of day’s practice will get you started with the Am and Em shapes. If it doesn’t then find someone to guide you about hand placement.
  • Another case for full barre chords is that you have the ability to mute strings when you want to emphasize a progression with powerchords.  Plus, you can easily mute all the strings to add percussion(try playing Nirvanas "Smells Like Teen Spirit" with just 3 string chords).  Sometimes people spend more energy and time trying to get around difficulties than the time and energy it takes to do it the right way.
