Random Helix FX question
EricTheWearyEricTheWeary Frets: 16297
I was wondering this, I presume the answer is No but I was curious...
Obviously you can run more than one effect at once on the Helix FX. Where an effect is wet-dry ( like delay or reverb) can you run an effect into the wet only?
So let's say you had a patch with fuzz and delay could you have the fuzz on the delay repeats only?
In my head this doesn't require any more processing power, it's about how the signals are routed.
Ta.
  • Not as far as I know. Interesting
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • EricTheWearyEricTheWeary Frets: 16297
    Ta.
    I appreciate it's something of limited appeal but I like the sound of filtered/ fuzzed/ modulated delays ( not sure I've ever heard a fuzzed reverb, but why not)and wondered if it had that capacity ( beyond any delay or reverb models it has that are designed to be filtered or modulated).
  • simonksimonk Frets: 1467
    edited January 2019
    Perhaps one way you could do it would be to run two otherwise identical delays but one of them being 100% wet... then put the fuzz after the latter.
  • rossyamaharossyamaha Frets: 2459
    Think you can. Let me have a play.
    Two identical delays in parallel paths I should have said above...
  • John_AJohn_A Frets: 3775
    edited January 2019
    If one path is 100% dry the delay needn't even be there, so run parallel paths, delay 100% wet on path 2 with the fuzz after it, job done
    Yeah, what he said.
    Run two signal paths in parallel, the one 100% wet with fuzz ( or whatever) after it. Makes sense. Presumably you can alter the balance of the parallel paths so you aren't stuck with 50-50?
    ( If one chain is 100% wet it will mean the summed signal is 50% wet presumably if you can't alter the balance of the paths?)
  • thecolourboxthecolourbox Frets: 9819
    edited January 2019
    Yes you set the level of the A and B paths at the mixer block on the signal flow
    soundcloud.com/thecolourbox-1
    Ahh,ta.
