Will this cheap tap tempo switch work with an MXR echoplex?
soma1975soma1975 Frets: 6826
  • simonksimonk Frets: 1467
    edited January 2019
    Yep, it should be OK... the Echoplex requires a normally open switch.
  • soma1975soma1975 Frets: 6826
    Excellent cheers. Was the smallest I could find.
    To confirm now I have it, it works perfectly. Billy bargain.
    I'd double check the requirements of the MXR, for instance Boss use a NC switch on a lot of stuff.
    You most likely won't like the wrong one; it'll work, but on the lift rather than the press of the foot.  They probably make both?
