Behringer B208D Eurolive Active PA Speaker + cover £80 SOLD
carloscarlos Frets: 3451
edited January 2019 in Amps £
Not much use outside the house. Can serve as a guitar amp if you put an amp modeller or amp on a box pedal in front of it.
I'm in Waltham Cross EN8
Details
The Behringer B208D Eurolive Active PA Speaker is a powerful and portable PA speaker which is capable of producing a huge 220 watts of output power from its compact size. Housing a single 8 inch speaker and 1.35 inch compression driver the B208D accurately replicates low, mid and high frequencies for a balanced response. Additionally the microphone and line connections as well as clip LED make the B208D EuroLive Pa speaker extremely versatile and suitable for a range of applications.
