Hello all
Forgive the newbie questions, I'm currently looking to update my set up. I've always used combo amps before but I'm keen to branch out to head & cab territory. Due to budget/transport limitations, I am going for a 2x12.
Someone has offered me a 1922 cab for a reasonable price. However, I was keen initially to get a Blackstar Series1 2x12, I adore the Celestion V30s and sort of had my heart set on em.
As the clumsiest person on the planet, I would like some opinions and advice. Would it be feasible or a good idea for me to purchase the cheaper cab (which has some variety of Celestion G12s in it) with a view to buying some V30s seperately and swapping one or both of the speakers out myself?
I'm sure there are many people on here who have had success doing this. Also - any views on having a cab with mixed speaker types in? I.e. 1x G12, 1xV30? And, is all of this worth the bother???
Cheers
The 1922 has been offered to me for £150, so actually as I can get that HB cab new for £160...be silly not to. And yes, it does make more sense to buy the cheaper speaker pair separately and do the swap that way round.
In terms of actually doing a speaker swap, is it a fairly straightforward process? Does it involve lots of shop tools i.e. ability to solder or anything? I can solder, just haven't done it for years and don't have the space/equipment...
Easy - a chunky Philips-head screwdriver is all you need. (I think the HB cabs use screws rather than nuts for the speakers.) The speakers will be fitted with push-connectors so you won't need to solder anything.
Last night I tried out my new setup, and I am totally utterly in love with it. Finally got the Blackstar Series One 50 head (bought new) running through a Harley Benton G212 vintage (found in local music shop for £70 - bargain)
I had previously tried the head out in the shop through a Blackstar 212 cab they had in there. The clerk did say that it had V30s in, but I suspect this wasn't the case, as I found it very clangy and tinny almost, from the low mids all the way up to trebles. I reckon that this was actually an older cab, before Blackstar started putting V30s in them.
Through this beat-up looking HB cab though...wow, what a difference. So punchy but deep and rounded at the same time. There's clarity there that I need, but not too much sharpness through the mids and trebs. At this point, I'm not rushing around to swap the speakers, but I will see how it goes.
Once again, big thanks to all of your for your help and especially to mart who put me onto the HB cab
Pic for good measure!
If you do end up wanting to swap the speakers, it is very straightforward. First, you'll need to remove the back of the cab.
The wires from the jack socket will be attached to little metal lugs on the back of the speakers - if you're lucky, they'll be little spade type connectors that will just slide off. If not, the wires will be soldered on. If they are soldered, you'll need a soldering iron to get them off (unless you want to cut them). Heat the soldering iron up and touch it to the solder points as you gently pull the wire - it'll just come away. (Just be careful not to drip any molten solder on the speaker cone).
The speaker will be attached to the front of the cab with some screws/ bolts around the edge. Undo them and the speaker will come right out.
Fit your new speaker, slide on the connectors (or solder your wires to the lugs) and rock out.
