Telecaster build: jack question
Presuming there isn’t a input jack that goes outside the body on a tele? Hole on my body is only big enough to get a few wires through. Don’t want to miss a trick before getting the drill out!
  • ICBMICBM Frets: 72632
    There are several styles of jack you can use which require different-sized holes, so the builder has probably intentionally left it up to the end user.
    The best is a Les Paul style or 'football shape' (depending on the curvature of the body there) metal plate with a standard open-frame Switchcraft jack. The Electrosocket 'upgraded vintage style' is also good, but the original Fender lash-up and any kind of barrel jack are best avoided.
  • Thanks @ICBM I’ll have a google for these then as I only have barrel jack and it doesn’t look friendly.
    The problem with them is that they’re unreliable and can’t be re-tensioned or even easily cleaned, so your only option is to replace.
  • I have the indent hole on side of body for barrel, I was talking about between cavity and hole before, so looks like electrosocket to finish this off.
