Thanks, Mr Soldano :P
There is one company which I think has been really successful at getting the valve-like response from a digital preamp and Class D output stage - and also coupled with, as far as I know so far, absolutely bombproof reliability... Blackstar. The ID series (60 upwards especially) is genuinely nearly there. I A/B'd an ID60 with a 50W valve Marshall at full rehearsal-room level and there was very little in it in terms of volume and dynamics.
What I don't like about the ID series is the actual voicing of the amp - typically Blackstar, and as Dave knows I don't like their valve amps either! - and most of the onboard effects, not the responsiveness and power delivery. And I certainly don't have any complaints about the build quality or reliability - I know several rehearsal studios who have bought them and to the best of my knowledge not a single one has failed.
One of the reasons for this is that, alone of any amp company I know of, they understood why solid-state amps "don't sound as loud as valve ones" - at its most basic, it's just that valve amps can put out up to twice their rated power when overdriven - but a solid-state amp can't, because you can't overdrive the power stage without it sounding bad even if it doesn't die. So Blackstar made the power section twice as powerful as claimed. Cheating? No... simply understanding the problem.
It's no use repeating that valve watts and solid-state watts are exactly the same (they are), or that a music programme signal's peak power can exceed the input power to the amp because its average is lower (it is), because if you don't understand that guitar amps are *intentionally* driven into continuous distortion, you're going to end up with a digital amp that simply doesn't perform remotely like a valve amp of the same rated power in the real world.
It occurs to me that there are actually two solutions to the problem of designing solid state vs valve power amps - either double the power so they remain clean as far as possible, or make them break up nicely like valve power amps.
While I'm not even remotely interested in owning such a thing, I'm definitely curious as to whether it's possible without losing the advantages of solid state amps (size and weight, apart from anything).
If you deliberately clip - and filter, to make it sound good - the input signal to the power amp at below the level where the power amp distorts, the power amp can never be pushed into distortion and so will not fail - assuming it's not run into a too-low impedance, and even that can be prevented fairly easily. OK, it does mean that you then need an amp which is twice as powerful as necessary.
Believe it or not, I've actually thought exactly that for about thirty years ever since I started wondering about this sort of thing, but until the Blackstar IDs I'd never seen it actually implemented.
Im guessing what we are seeing is simply a shortfall in the fidelity of the model (and arguable both the preamp and power amp components of that model as my experiments show).
the other possibility is that the interaction of the guitar itself with the reproduced sound is somehow different, even at roughly the same volume.
In any case...I've found that FRFR isn't the best way to use modellers. They sound much better with a big-ass power amp with way more headroom than you need, and a real speaker cab.
Haven't found that either and done more A-Bs than enough. To my ears a well set up modeller sounds as good as a valve amp these days
Dont know if i would def be able to make the call if I wasnt playing, especially as in both cases I was trying to get a good sound rather than necesarily a matching sound if you see what I mean.
I found the best sound I got with my Tonelab was when I ran it through a Marshall power amp into a 4 X 12 ..... you can't model a 4 x 12" .... you can model the frequency response but you can't model the spread of sound coming from 4 different speakers
There's a nastiness that gets filtered out via the output transformer in a real valve amp .... that's why valve state stuff never really did it .... transformers are non linear at audio frequencies and add distortion but that kind of works for us. To the point most guys are happy with diode and op amp clipping for their drive sound as long as it goes into a valve power amp .
I would say a basic speaker in a cab with a simple push pull valve power amp with no tone controls would be ideal for a modeller ... you could pick your amps but not bother with the speaker sims and mic positions etc.
I agree that a valve power stage is where the dynamic response an 'presence' comes from though.
The other revelation is the snapshot mode - ie the ability to have a variety of different pedals switched, and tweaks to any number of settings activated mid-song with a press of a button is genius.
Haven't tried it live yet - that'll happen for the first time in a couple of weeks. Plan is to use a PA speaker on stage for monitoring and a bit of backline, and also to feed some to FOH and see how we get on. Gonna be a bit more of an experiment to begin with than just using an un-mic'd Blues Cube and nothing else, but looking forward to the challenge!
