WITHDRAWN : Trace Elliott Ta 300 Acoustic Guitar Amp
StrummyBrummieStrummyBrummie Frets: 265
edited March 2019 in Amps £
Top drawer acoustic guitar amp. Check out the spec below. Excellent condition, comes with 6 button footswitch, all leads, dust cover and manual.
Basically a small PA and a wonderful piece of kit. Now discontinued, but they were just shy of £1200 when they were available.
£350
Open to trades/ PX. There is a deal to be done
Collection from Birmingham, but delivery may be possible.
TRACE ELLIOT TA300 FEATURES:
  • 2 preamp channels with 300 Watts total power output (200 Watts from internal speakers 100 Watts from extension cabinet).
  • 2 x 5" (127mm) special design neodymium Celestion (connected in stereo) and 1 x 12" (305mm) G12 Century Vintage neodymium Celestion speakers.
  • 1/4" (6.35mm) jack input with Piezo switch, to switch to ultra-high impedance input stage on Channel 1.
  • Combination balanced XLR / 1/4" (6.35mm) jack input with Phantom power switch on Channel 2.
  • Lo-Trim & Hi-Trim rotary controls on Channel 1.
  • Gain & Notch filter rotary controls on both Channels.
  • Built in auto-compressor on both channels.
  • Signal level LED on both channels.
  • Shape switch for instant EQ'd sound on both channels (footswitchable on Channel 1).
  • Phase switch to help with control of feedback (footswitchable) on both channels.
  • Effect Parameter and Setting rotary encoders.
  • Allows for separate levels of Reverb to be applied to each channel.
  • Channel 1 can also have either Chorus, Flange, Phaser, Tremolo, and various Delay's including stereo Ping Pong.
  • Tap tempo (from either front panel or footswitch).
  • 6 bands graphic EQ.
  • Feedback Locating System on each band of EQ that uses LED's to show where feedback is occurring.
  • Master volume and Mute switch (footswitchable), mutes all outputs except Tuner Out.
  • Tuner output, Left and Right Preamp Outputs and Power amp Inputs (to use as effects loop).
  • Two DI outputs; can be configured as dry Channel 1 and Channel 2 out, or processed Left and Right channels out.
  • Switch for turning front panel lights on or off.
  • Power section featuring Dynamic Correction.
  • AFC-6 6 function footcontroller with stage length cable and durable slip on cover included.
  • Dimensions (HxWxD): 23.2'' (590 mm) x 17'' (432 mm) x 12'' (305 mm)
  • Weight: 26 lbs (12 kg)
