Palmer vs Pedaltrain
lincolnbluelincolnblue Frets: 294
I am torn between the Palmer pedalbay 60l and Pedaltrain  Novo 24
Other than cost, what's the benefit of each? which is better?
  • BeexterBeexter Frets: 598
    Palmer has adjustable feet so you can fit a power supply under and adjustable rail spacing. And it's cheaper. No brainer in my book .
  • Palmer bags seem a bit thinner. Boards are both good.
  • VJIvesVJIves Frets: 466
    Adjustable slats on the Palmer range changed my life.
  • timmypixtimmypix Frets: 2392
    If you want to save even more money, I'm pretty sure the Thomann/Harley Benton pedalboards are just Palmers without the branding - they look identical.
    Tim
    I assume it's plenty sturdy enough?
    Just had a look and it certainly seems the same. About the same price though... Maybe only £5 cheaper. I have a hard case for my home made board at the moment but want to reduce weight so might go for a soft bag this time
  • I’ve got the Palmer and it’s excellent. The adjustable slats are brilliant. I’m also selling the Palmer as I’ve got a Kemper and don’t use pedals now.
    http://www.thefretboard.co.uk/discussion/138159/fs-palmer-pedal-bay-60l#latest
    Check out my band Coral Snake if you like original hard rock!
    Just replied on that thread
  • @lincolnblue ;
    also consider the Warwick Rockboard series. Those are great. Holes for your cables to go through, but no slats so you can position your pedals anywhere.
    Bye!
  • @lincolnblue ;
    I do like them too but they're quite a bit more expensive
    100%
    100%
    Just ordered one from @chrishill901 . Size is ideal too as I want to get a Quartermaster or similar
