What it does is it removes all the high frequencies from one coil, but leaves the very deep lows so you will still get the 50Hz hum cancellation. If I remember rightly this was originally a Bill Lawrence idea.
Kindest regards
Jay
shouldn’t the cap/resistor be connected one end to the pot casing and the other end to the lower terminal shown in the diagram?
So with the switch up, the series connection is isolated; when down the series connection is shunted to earth, but via the cap/resistor...?
please correct me if I’m wrong...
Which colour codes are wrong? I’m not familiar with those pickups.
[Imgur](https://i.imgur.com/JHsEMcn.jpg)
