'Tis annoying though.
Fit a switch in the speaker circuit and switch speaker on a few seconds after the amp. Probably good as well to fit a 1k resistor across the speaker jack to allow the output cap to charge if there is one but handy for a DC coupled amp anyway.
Dave.
8-)
I would not be happy with anyone who has to ask advice here doing ANYTHING around mains circuits. In any case, after such work the amp would need a PAT test, certainly before it was sold.
This is a solid state amp anyway and the thump is caused by the settling of the voltages in the output transistors and really the only way to fix it is to NOT have a speaker connected for the few seconds it take the power stage to sort itself out.
Dave.
https://thumbs.static-thomann.de/thumb/thumb150x150/pics/prod/165014.jpg
It will, good idea but, if you have such an amplifier and especially if it is of 10W or greater power, check the PCB around the headphone jack from time to time. Jack switches are not rated for several amps of AC, can get hot, cook print and cause dry solder joints.
Dave.
