What should I be looking at?
I've got a decent interface for home recording and for location (or practice session) recording I've an old Tascam handheld recorder.
What I'm looking for is something portable, more modern, better inbuilt mics, but, also 2+ xlr/mic inputs for spot micing, all to be recorded as separate channels at the same time. It will mostly be used for recording acoustics and vocals, but, occasionally fiddle, squeezebox etc too. I'm not expecting a seperate channel per instrument, but, a good stereo presentation from the inbuilt mics would be good and the ability to add in a vocal mic, or pair of condensors to give better scope for mixing back home would be ideal.
Batteries would be good, though, in some instances it might also be run from the mains.
I'm not looking to do any mixing from this device, just record. Any processing and tidying up will be done on the computer at home.
Cheers
Though first hand experience or standout products that I might not be aware of would be ideal
it has just just about everything you've asked for.
