https://i.imgur.com/YDUgQG1.jpg
D2 is a reverse polarity protection diode, D1 is a 5.1V Zener that should set VB at 5.1V, with VA then being the bias voltage fed to the FET gates. The node common to R26 & R27 reads around 8.6V, so something is going wrong after R27. I'm going to try and replace D1 because it's either this or C12 that looks to be the culprit, and I'm more likely to have damaged a semiconductor device than a capacitor. This is where I miss Maplins, I'd just pop round and get a couple of diodes, now I have to buy them online and wait a couple of days!
Could this be a problem with the switch? I’ve destroyed one in the past with two much heat but I was quick and careful when soldering this one in.
