Since it appears that the cabs are closed-back - there look like there are some small round ports in the lower corners - I'd probably go even further and say that it's unlikely you'll blow the speakers even if you do crank it, but that wouldn't be the best advice .
Never be afraid to ask. The newbie who doesn't ask - and has just enough knowledge by himself to be dangerous - plugs his friend's bass into his hi-fi and promptly blows both speakers...
To be fair it was before the internet and I was only about 17 at the time .
https://i44.photobucket.com/albums/f28/snipershot7990/20190224_212603_zpsxsnvekyk.jpg
Exactly! In a closed-back cab, they would be ports to tune the low-end a bit. In an open-back cab they won’t do much at all, so I suspect it’s a case of muddled design...
