Out of curiosity I took the tank out of the amp (still connected) and noticed the reverb circuit is quieter when turned up.
The ‘stock’ screwed down position of the tank is dead centre on the bottom of the cab, with the rca sockets facing the front grille and the white connector nearest the 6V6’s - is it advisable to move it to one side/back/forward?
I’m noticing that anywhere above 3 on the reverb there’s an audible hum (at home volumes) - is that normal for a valve driven reverb? I’ve tried swapping recovery valves and that doesn’t seem to make a difference.
If you can find a better position in the bottom of the cab then simply screw it down there instead - but some hum is inevitable, the return transducer is essentially a single coil pickup.
At some point I’ll probably replace the accutronics tank with a deeper sounding TAD one.
