Jcm 900 dual reverb
billandobillando Frets: 32
Does anyone use an attenuator with a Jcm 900 dual reverb for gigs? If anyone has tried this do they prefer the attenuated sound or master low?
«13
  • billandobillando Frets: 32
    I find at drummer level I can get the master to 3.5 (gain at 2pm). I think sweet spot on these is around 6 on the master but when I'm there I have to attenuate a little. I have had nearly every attenuator over the years (ps2 now) and it def takes a life from the tone. Just wondering if anyone uses an attenuator with the jcm 900 amps.
    Never needed it in a 900, I find the volume control adequate
    I find it good too but have u compared it in a live situation with an attenuator?
    Yes, I don’t think it needed it. I use to use a 4500 head into a 412 and never needed any sort of attenuation.
    Are you bridging the fx loop with a patch cable and winding up the fx mix to about  11 o’clock?
  • ICBMICBM Frets: 72485
    This really doesn’t do anything. There are no extra components in the loop circuit apart from the level pot and some resistors, which are bypassed when there’s nothing in the loop. You may get a very slight change in volume due to the two halves of the level pot not tracking each other accurately, but that's all.
    (The bit inside the dotted box at top right and middle left.)
    It does something different to the sound, it adds low end and adds a responsiveness to pick dynamics.
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    With respect, you’re imagining it. There is no additional circuitry which could do that.
    At most, it’s increasing the signal level very slightly which will have exactly the same effect as turning up the master volume by the same amount.
    It’s not even the same as something like the Fender Hotrod which uses an IC for the send and return.
    Didn’t Randall Smith say that “every single part is a tone control in an amplifier”?  ;)
    Not imagining it at all, it’s something a lot of 900 owners do and have done since the amps release.
    Just look at the schematic and explain to me how it can be so.
    There are no active components in the FX loop. All you’re doing, at most, is increasing the volume slightly.
  • octatonicoctatonic Frets: 33805
    @ICBM is correct.
    I don’t need to read a schematic, I can hear a difference as have many 900 users over the years.
    It's physically impossible to hear a difference.
    1reaction image LOL 0reaction image Wow! 7reaction image Wisdom
    edited March 2019
    Thousands of people genuinely believe they can hear a difference between mains cables and different brands of caps in guitar too, but they’re still imagining it.
    There may be a small volume change - the loop has two level pots (on the same physical shaft) which work in opposite directions, and some extra resistors which are intended to maintain the same signal level as the pot is turned but don’t quite, so what you may be hearing is the well-known psycho-acoustic effect that a slightly louder sound sounds ‘better’ rather than louder - but there isn’t any real change that wouldn’t occur if you just turned the volume up by the same amount.
    This is how religion managed to take hold.
    1reaction image LOL 0reaction image Wow! 10reaction image Wisdom
    I’d rather trust my ears and first hand experience than a man in Scotland who has no time to actually fix amps because he’s too busy posting on Internet forums.
    8reaction image LOL 9reaction image Wow! 0reaction image Wisdom
    Lol
    I also have a lot of first-hand experience with these amps, *and* I can read a schematic :).
    0reaction image LOL 1reaction image Wow! 8reaction image Wisdom
  • poopotpoopot Frets: 9099
    have you tried pulling two of the power valves out and running it at half power?
  • fretmeisterfretmeister Frets: 24441
    ha ha hahahahahaha!
    You're the reason that audiotard IEC power cables can charge £1500 for a kettle lead!
    If it doesn't show up on a 'scope you ears cannot hear it.
