A correctly sited standby is useful and can extend power valve life a bit, depending on how hot the amp runs at idle - better than a thermistor.
The standby needs to be after the first filter cap, not before it or in the centre tap connection of the PT.
Bandcamp
Spotify, Apple et al
Absolutely agree. Yes I know "they" fitted them to the A series but I wish they hadn't. Still, it would I think be hard to sell a "classic" handwired all valve amp without one!
FYI the HT-5 opens the AC feed to the sstate bridge and the rest of the HT and S1 series just slam -100 volts or so on the power valve grids.
Dave.
Bandcamp
I still think that turning the HT off is the best method because it can help with troubleshooting and makes it safer to work on the amp. It's not just a mute switch.
