Wouldn't it make more sense to use angled cables in/out of a pedalboard?
TimmyOTimmyO Frets: 7504
I look down and see those straight jacks heading left and right from a board - just begging to be stepped on - does anyone use angled jacks instead?
Red ones are better.
  • stickyfiddlestickyfiddle Frets: 27135
    I’ve always used angled. Much neater :)
  • Yep. All angled.
    'Vot eva happened to the Transylvanian Tvist?'
  • LastMantraLastMantra Frets: 3824
    edited March 2019
    Both. Depending on socket positions.
    I do make my own and swap pedals about all the time playing at home.
  • digitalscreamdigitalscream Frets: 26665
    Yep, always have. Once is enough for having the singer wreck pedal jacks.
    <space for hire>
  • ArjailerArjailer Frets: 103
    Yep - angled in and out of the board  :+1:
  • ICBMICBM Frets: 72490
    Yes, angled at both ends if possible. I have a few with one of each for places a right-angle plug doesn't fit properly, but probably too many really.
  • ZenOvertoneZenOvertone Frets: 234
    Another one, yes to right angle jacks to avoid the clumsy feet of others
    Yep
    Feedback
  • TimmyOTimmyO Frets: 7504
    Right. So just me that’s not been doing it then!
    Yes angled in and out of my board. Only takes a clumsy drummer squeezing out from behind his kit and over my board to step on a straight jack sticking out.
  • SassafrasSassafras Frets: 30301
    The only straight jack I own is the one going into my Strat.
  • GadgetGadget Frets: 896
    Whichever you use, consider using a pedalboard patchbox for incoming / outgoing cables, which saves wear and tear and damage to actual pedals. Bright Onion and others do them and cheap too, relative to the pedals we use...
    I think, therefore.... I... ummmm........
    Yes, and you can also bolt - not velcro - it to the board, so that even if it gets a really hard pull on the cable it won't come loose, so it will protect the pedals. With a modern Pedaltrain type board it should fit underneath out of the way too.
    The flaw I can see with that is that the jacks are too close together and not far enough above the floor to use right-angle plugs, so we're back where we came in...
    They fit all angled to one side fine
    But it wasn’t being offered as a solution - just showing what I have.
    actually I take that back - if the floor is hard rather than carpet, it means forcing them in hard against each other - less than ideal
    You're better to angle them upwards instead. I should have thought of that in the first place :).
