Weber MiniMASS impedance question..
equalsqlequalsql Frets: 6117
I have a tweed 5e7 clone that feeds  its 4 Ohm output into 3x8 Ohm speakers wired in parallel to produce a 2.7 Ohm load (as per the original Fender design).  I wish to use an attenuator with the amp and have been checking the Weber models.
The Weber MiniMass has a 4 Ohm input..does anyone know if this would be safe to use given the amp's impedance mismatch with its speaker load.. or would I need to opt for a 2.7 Ohm specific model like the THD green Hotplate?
  • ICBMICBM Frets: 72350
    Always match the amp and the attenuator, don't worry about the speaker - the amp sees the attenuator as the load not the speaker, unless the attenuator is almost completely bypassed. So a 4-ohm attenuator is ideal.
  • equalsqlequalsql Frets: 6117
    Thanks @ICBM, I was hoping you might be monitoring the forum  :)
  • The mini mass was the worst attentuator Ive ever owned. Theres an ultimate for sale on here I think. Now thats a grerat piece of kit
  • DodgeDodge Frets: 1443
    Putting the 32 ohm Ultimate Attenuator on an amp expecting 2.7 ohms is asking for trouble.
    I did not like the MiniMass at all either - but the "Ultimate" was at least as bad… mediocre-sounding, poorly built, and I'm not at all convinced that a 32-ohm load is a good idea for anything other than a 16-ohm amp, despite what they say.
  • crunchmancrunchman Frets: 11449
    I've got a Minimass.  It's very amp dependent. It sounds good with some amps and awful with others.
    I'd probably be willing to sell it if you are interested.
