Gibson Sonex-style Bridge Posts????
HarrySevenHarrySeven Frets: 8033
edited March 2019 in Guitar
Can anyone advise re. a source for this style of post?
http://i.imgur.com/ZeAWUJo.jpg
Sorry for the dire image quality - I found the pic on the web.
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • sawyersawyer Frets: 732
    Amber Guitars Tokai conversion studs?
  • ICBMICBM Frets: 72513
    I’ll have a look in my scrap parts box later... I think I might have some.
  • HarrySevenHarrySeven Frets: 8033
    Thanks both! :)
    What diameter are the post holes in the body? I've got a pair which are for 12mm holes. They need the height screw threads replacing since they're bent, but they're actually just standard bolts fed through from the inside of the posts! So that should be no problem.
    I’ll check the diameter ASAP
  • FunkfingersFunkfingers Frets: 14532
    I may have some Gotoh Tone Pros inserts.
    @ICBM - Bridge post holes on Chibson = 12mm (+/- a wee bit).
