Check the neck angle and bridge positioning, which were both issues on a 2010 R8 that I had.
The neck angle on mine was too high, so the bridge had to be really high. That meant it sat very high on the posts and tended to tilt. You could make it ok by screwing the action down very low, but it was lower than I normally like in a guitar.
The bridge on that one was slightly out of position as well. I really struggled to get the intonation right. At one point I put a Nashville bridge on it, as it has more travel for the saddles, but that didn't sound as good. I put the original back on, but I'm not sure that I had the intonation quite right on all the strings. One of the guys who used to work in the repair department at Chandlers told me that if it was his, he would have filled the bridge post holes and drilled new ones 3mm away.
The other thing to check is that you like the huge neck on it. It really is massive. I found it very comfortable, but it was quite cumbersome to play. I have very short fingers, but there were things that I struggled to play cleanly on that guitar that I could play quite easily on a different guitar. On the other hand, I could play if for a long time without my wrist and hand getting fatigued.
If the neck is too big, then the 2017 version of the R8 has the 59 neck profile. There was one of those for sale in the classifieds earlier in the week. There might be a few others who bought one in the big blowout last year who are coming to the end of the honeymoon period. I'm sure there will be more for sale.
what colour are you after?
Go for it if you enjoy how it plays, like the looks of it and can afford it.
I have had a few 2014’s and they were all great. My 2017’s are exceptional.
Rob
If the bridge is too is too high it will touch/be very close the edge of the bridge.
