Tubescreamer in front of OD pedal
HootsmonHootsmon Frets: 15972
A TS into an OD for a leg up in volume and a little more saturation.......war's the ballpark setting ( on teh TS) for a good starting point for this here application?
Thanks peeps   :)
tae be or not tae be
  • HootsmonHootsmon Frets: 15972
    Since i am here.......what difference do active tone controls on an OD pedal make compared the the regular passive ones?
  • rossyamaharossyamaha Frets: 2452
    Everything at noon and go from there. However....
    Try putting it after the OD. One of my favourite things to do. It does the volume boost thing if you want to but can add gain and either really thicken things up or give you an extra mid cut for a solo boost or alternative gain tone. I sometimes run 2. One for thick gain and one for brighter gain. Usually after a clear/ transparent drive.
  • munckeemunckee Frets: 12390
    I have compressor into overdrive into tubescreamer.
  • KebabkidKebabkid Frets: 3307
    I run a Keeley TS-808 into an OCD. The 808 gain is set at 10 o'clock, the OCD's at 1 o'clock. I can push the 808 more if I wish, but I suppose it depends on how much gain you have on the other pedal and whether you will encounter feedback, noise etc
    When stacking, I like setting pedals low to medium gain and finding a useable setting that allows them to still be used individually.
  • Adam_MDAdam_MD Frets: 3420
    I'd run the tubescreamer after most other ODs as well if i wanted a volume boost.
  • ICBMICBM Frets: 72414
    A Tube Screamer *is* an overdrive pedal... so whatever setting sounds best with whatever the other pedal is. It will vary depending on how you have the other pedal set.
    As Kebabkid said, stacking usually works best when the pedals are set fairly conservatively rather than flat-out.
    The tone control in a TS is actually a mixture of active and passive. Turning it down rolls off treble from the previous IC stage passively, turning it up actively boosts treble in the next IC stage.
    Many thanks all  :)
  • Winny_PoohWinny_Pooh Frets: 7771
    edited March 2019
    I prefer a Clark gainster or clone for this job as it's less compressed and muddy.
    That's one to add to the build list I keep forgetting about the Clark Gainster.
  • dilbertdilbert Frets: 203
    Bad Monkey to boost OCD clone, then into Riot for me. Next week it will be............. well something else =)
    Signed:  C. Apricious
