WTB. Neck shims
Jeddy3Jeddy3 Frets: 80
Hi. Looking for some neck shims to try on my Strat. Preferably full neck pocket tapered ones but open to anything. Wondered if if anybody had some going spare before buying any.
Cheers,
Dan
  • finest1finest1 Frets: 94
    you may have to make it yourself. its a raging debate whether partial shims are better than full neck ones.
    let me know if you manage to source any
  • Jeddy3Jeddy3 Frets: 80
    Yeah I've seen some partial brass ones on ebay and the stewmac ones are a bit too steep. I experimented with a playling card and pick and now not entirely sure it actually needs shimming. Just feels stiff to play for some reason and I've played around with everything else set up wise  :s
  • axisusaxisus Frets: 28347
    I've used bits of cornflake packets for years. Rock n roll.
    Wouldn't dream of buying something made for the purpose.
  • sweepysweepy Frets: 4205
    Stewmac and Allparts sell full neck pocket shims
  • fretmeisterfretmeister Frets: 24656
    I use folded sand paper or wet n dry.
    Grips the pocket a little then too.
    My shim of choice is self adhesive glass paper, doesn’t slip and grips perfectly
  • jaymenonjaymenon Frets: 836
    I have four Stewmac shims
    - one 1°
    - two 0.5°
    - one 0.25°
    I've got one partscaster on the go - once I've put it together, I'll know which ones will be spare - if you have the time to wait...
    - one 1°
    - two 0.5°
    - one 0.25°
    Ah ok thanks. I don't mind waiting  ;)
