I'm currently considering the Flashback Triple Delay as a neat way of using multiple delays simultaneously but I'm wondering if there other units out there that I should consider. I currently use the Dunlop Echoplex, a delay that I like very much but if I wanted to add another delay to that unit I'd be looking at another device in order to get parallel play-out - something I'd like to avoid, so the Triple Delay looks like a good option but are there any others out there? ps. I'm not keen on multiple controls and deep editing menus, more of a set and forget kinda guy.
Say you turn on engine 1, and tap in the tempo ... then turn on engine 2.... engine 2 wont have the same tempo as engine 1. IE: It doesn't have global tap tempo, and as I recall you can't tap the tempo in for an engine when it is bypassed.
Killed it for me. Sent it back.
Actually really liked the unit and the sounds. But the lack of global TT was truly mystifying...
If all three delays are active, would tapping then update all simultaneously, or can you only tap when a delay is being edited?
That might do the job. I think it's smaller than the TC too.
Personally I don't much like the TC sound.
Agree with you about the TC sound, never been very impressed by stuff of theirs i’ve tried (hof, corona), clean and efficient but a bit soulless.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Also, it doesn't have analogue dry-through like almost every other delay out there, so if you put it in a parallel loop the entire signal goes slightly out of phase with the parallel signal (since the A/D conversion is on the main signal as well, which introduces latency), which is dumb.
Think I'm going with the TC Triple Delay for now, it's simple, sounds good and I can spend some time working out if three delays in parallel is going to work for me before diving in the expensive end of the pool.
Very different beast to something like the Flashback or Timeline, though.
