Subzero 5w valve Guitar head amp
eldarvanyareldarvanyar Frets: 32
Hi,
I have just come across the subzero 5w valve guitar amp. I think it may have a 12ax7 and el84 driving it. I have only found a couple of videos on YouTube.
Does anyone have any experience of these amps and can recommend them?
Thanks
'Less is more' or is it 'more is less?'
  • chrisj1602chrisj1602 Frets: 3965
    I know someone who has been gigging the 50w head and 212 cab for a few years, sounds decent and no issues as far as I know.
  • SlopeSoarerSlopeSoarer Frets: 823
    I have the 20w version (which I picked up for £130) and love it. Apparently it is the same wiring as a Fender Blues Junior.
    I like it so much I'm going to buy the 5w version for another room.... I'm hoping to get one for around £50 used.
  • DJH83004DJH83004 Frets: 196
    I've had a few 50watt heads in the workshop, and the build quality is surprisingly good, the thing that let these particular amps down was the Chinese mains transformers, but not massively expensive to change if they go.
    You might want to read this, aparrently they are dangerous.
    https://www.ratvalveamps.com/subzero-tube-20r
  • longjawlongjaw Frets: 423
    Would it not be better to report this to Trading Standards if the amp is dangerous?
    To be fair I've read that. I checked what I could, no issues with the screws on mine (neither to long/interfering or loose). Regarding the fuse I couldn't possibly comment though I do have a great circuit breaker: )
    Sound wise it is excellent.
    Some of the finishing could be a little better (not that it is poor) on a couple of areas where the tolex is pulled around compound curves nothing as bad as shown in RATs photos.
    Maybe quality control has improved or I just got a good one.
  • KeefyKeefy Frets: 2286
    He Likes His Capital Letters Doesn't He?
  • Arktik83Arktik83 Frets: 431
    edited April 2019
    I bought a 20w combo and they had the exact same issues as Andy at RAT Valves described.  I sent it back and advised Gear4Music of this, didn't get anything back from them about it.
    If you do get a subzero amp head or combo, may be best to just check to ensure the screws aren't touching the PT etc.
    Definitely no screw issues with the 50watt heads that I have looked at, but being a head you wouldn't really expect there to be a problem as the screws access through the bottom of the cab, into the chassis, well away from any components or the PCB.
