Good compact PA speakers??
Hello,
Looking for some recommendations for a small/compact PA speaker for acoustic/vocal duo. I have a mixer already, but no 'working' power amp, so it would be good if these were powered speakers
Thanks
Brian
  • John_PJohn_P Frets: 2750
    Might be worth a look at the turbosound Milan speakers.  I’ve got a pair of m12 but the m10 would work fine.  As they have two inputs with volumes you’ve have a backup if you’re mixer had a problem and if you get reverb from a pedal you could just go direct.
  • revsorgrevsorg Frets: 880
    Do you have a budget?
  • GadgieGadgie Frets: 96
    Thanks John_P
    revsorg. no real budget as such. If they are compact and good sound/quality etc I'd be tempted
  • WhistlerWhistler Frets: 322
    No budget, as in no limit or no money?
    My wife and I use a pair of Alto TX208 powered monitors (£109 each) which we sit on a pair of speaker stands (£26 a pair) which we are very pleased with.
    Well I sort of meant I have a budget, but it's not money no object
    Thanks for the recommendation on the Altos
  • John_AJohn_A Frets: 3775
    edited April 2019
    RCf 708 or 710
    yamaha DXR 8 or 10
    db technologies flexysys fm10
    Qsc cp8 or k8.w
    rcf hd10
    turbosound iq
    would be my recommendations
    personally I’d avoid altos, they are great for the money, but not great, similar to the Db b-hype range, definitely not pro quality IMO, but may be good enough for a vocal only pa in a not so loud band
    if you want to down the route of power amp and passive speakers I’m selling some RCf Monitor 8s which sound amazing but after passive, pair them with something like a Behringer nx3000 and you’d have a very high quality rig for not a lot of cash
    if you’re after cheap, great sounding but not so great looking I’m also selling a hi audio pro 8 active which has a passive out and a Nova 8” passive
    the nova is in great nick, the Hk has a few knocks
    there are, however a million options depending on budget, how loud you need (venue sixpence, style of music’ and how compact you need them to be.  Also are they only going to be used for vocal and acoustic, or would something that could be stretched to a bit more be us ful?
    Requirements like pro quality, really loud and dirt cheap are probably unrealistic;)
  • Depending on size of gigs I would have a look at HK Lucas and Nano range,
    www.maltingsaudio.co.uk
  • What about an array system?
    I use 2 EV Evolve 50s, but 1 would be more than good enough. Fantastic sounding across all frequencies and very portable. Yes, they're a bit pricey, but worth every penny
    Thank you for the suggestions. I'm going to look into those. I was already looking at QSC CP8. I was also looking at a Curv500
  • JayGeeJayGee Frets: 1260
    Yamaha do a couple of neat options with a small (but perfectly adequate for an acoustic duo) mixer which tucks into the back of one of the speakers and has a storage space for leads etc built into the other one.
    An acquaintance has been using an earlier version for vocals only PA in a bigger band, hosting open mic nights, and the odd acoustic gig for some years very successfully. Sounds better than just OK In those applications, has proved itself robust, and about as compact as you’re going to get...
  • andyozandyoz Frets: 718
    edited May 2019
    Lots of options covered here already
    I'd be going for 10" two way actives myself for acoustic duo without backing tracks.
    Yamaha's range offers crazy long warranty (7 years?) which is important for gear at these price points. Their new DZR range are nice but pricey. The older DXR10 is great value though.
    I like sound of the RCF Art series but the lack of the full grille design personally puts me off visually.
    I think dB Technologies are doing great things at their price points. They've a few 10" options right up to the pricey DVX D10 HP (I'd buy the Yamaha DZR10 over them probably for warranty and better badge for resale)
  • ICBMICBM Frets: 72408
    edited May 2019
    Just for a bit of amusement, if you want to find out how far PA speaker technology has come in the last 40 years, yesterday I was given a pair of these, for free...
    Peavey SP-3s from the late 70s or early 80s. They're passive 1x15" plus horn, are rated for 100W RMS continuous and 200W programme, are almost 3 feet tall and weigh a staggering 93lb (42Kg) each!
    They're probably pretty efficient, so if they work they might actually be useful for a rehearsal room with a little old-school 150W amp or something - where they will never need to be moved again - but just imagine having to gig with gear like this back in the day!
  • MusicwolfMusicwolf Frets: 3655
    Back in the 80s we used to gig the working men's clubs with a 150w Carlsbro head + a pair of these
    Pretty much the standard back then.
    edited May 2019
    @ICBM ...I remember those days well.
    I just noticed Yamaha has released a Mk2 version of their popular DXR series. Main diff seems to be better horn (larger diaphragm with neo magent so they've skimmed some weight, also improved DSP apparently).
    Decent price hike too so good time to snap up the original DXR10's
  • kennedydream1980kennedydream1980 Frets: 1156
    edited May 2019
    This guy is selling some EV SX300 speakers with a power amp for £400 on Facebook. Might be a worth a look:
     https://www.facebook.com/d.i.evans
