Does anyone know what size Allen key I should use to adjust the truss rod of a Yamaha Pacifica 303-12? I think it’s from 1996 if that makes a difference.
I can’t seem to find a definitive answer online, and I haven’t got anything that’s an exact fit.
I’ve just got this guitar second hand, and I’d like to adjust the truss rod a little bit, and check that it’s actually working properly.
(The opposite way round applies to US 1/8" sockets, eg on the USA Standard Fenders - a 3mm key will almost always damage these and mean the nut has to be replaced.)
The 5mm fits in but it seems a little too small - there's a little bit of movement left and right. So I don't want to damage the nut by trying to use that. And the 5.5mm is definitely too big.
Not sure what to try now. The nut looks alright, it doesn't seem to be damaged.
Anyway I've just been to see a guy in a local guitar shop, and he put a bit of oil on the truss rod nut, and although still quite stiff it seems to have loosened up enough to adjust.
So thanks to @SteveRobinson and @ICBM for the advice and encouragement!
