Strat tremblock recommendations
adampeteradampeter Frets: 775
Preferably with a push in type trem arm
  • cbellangacbellanga Frets: 572
    Callahan?
  • sweepysweepy Frets: 4184
    Why not just buy a Wilkinson Vintage trem, Steel block and push fit arm
  • adampeteradampeter Frets: 775
    Its a CS strat and i wanted to just replace the block, the old arm has threaded
  • merlinmerlin Frets: 6691
    edited April 2019
    I recommend Kevin Hurley's blocks. They come with a (I think) teflon socket that holds the arm better than a Fender spring. He'll make you whatever you need in a variety of metals. Cheaper than Callahan and every bit as good.
    kevinh66@hotmail.co.uk
  • KittyfriskKittyfrisk Frets: 18822
    Clearly CS quality is up there with the best  :o  But seriously, if the arm has threaded/stripped, then the block might not be OK, so why not just replace the unit as @sweepy suggested?
  • JonathangusJonathangus Frets: 4539
    There's a Kevin Hurley block in the classifieds at the mo.  Might fit.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • zepp76zepp76 Frets: 2534
    I got mine from eBay, there's loads of choices on there. Mine is very good quality.
    Tomorrow will be a good day.
  • have you looked at Wudtone? Its not a push in arm though
    http://www.wudtone.com/wudtone-hardware/
  • guitars4youguitars4you Frets: 14292
    Not sure he is still making any - I've used them in the past - Not purchased any recently, but I was told he has called it a day - Update if you know further
    I think you misunderstood me, i want to replace the block and arm because they are threaded, appreciate not everyone rates CS stuff but i like the fender vintage look and sound
  • CasperCasterCasperCaster Frets: 762
    edited April 2019
    @adampeter ;I've had a few from Kev Hurley and they are excellent, and great value for money, but if you want CNC precision get a Callaham one. Alternatively the Fender US AVRI ones are available (block and arm sold separately), e.g.
    https://www.firstguitars.co.uk/shop/fender-strat-rolled-steel-2316-block/
  • John_AJohn_A Frets: 3775
    I’ve had both Callaham and Kev Hurley blocks and they are as good as each other, I.e. excellent.  The arms aren’t push-in but there is a nylon insert that removes any slop at all
    Thanks everyone, going to try and buy the hurley one thats for sale on this forum
