It turns out that jack input nuts are not all the same
ReverendReverend Frets: 5003
I lost the nut from the jack input on my Ibanez Destroyer a couple of weeks ago. Tried to replace it with a Gibson one but it was too big.
I sent a message to the distributor asking where I can find Ibanez-sized replacements but they have not replied.
Any ideas where I night find them?
Thanks
  • AlegreeAlegree Frets: 665
    I sell import sized jack washers and nuts.
  • SteveRobinsonSteveRobinson Frets: 7038
    Best thing is to replace the jack with a Switchcraft one.
  • ICBMICBM Frets: 72419
    This.
    Make sure it has a shakeproof washer - you can buy them separately if the seller doesn't include one - and it's best to put a bit of superglue threadlock on the thread before you tighten it fully ratchet-handle it like you're bolting the wheels onto your car.
    Then it will never, ever come loose again. I do them like this for 'demanding applications' - schools guitars! - and they don't come back with the jacks loose again...
  • richardhomerrichardhomer Frets: 24815
    ‘Output’....
  • mrkbmrkb Frets: 6879
    Wouldn’t Ibanez be metric, and switchcraft imperial? I’ve loads, but can’t work out which type is which.
    Karma......
    Ebay mark7777_1
    Yes. Far-east ones are the slightly smaller ones, US the slightly larger. Often the US nuts are 'milled' rather than 'stamped' too, so they have cleaner and sharper edges. Far-east ones are almost never milled.
    This.
    As always- this.
    FWIW the way you get them off if you ever need to is to put a soldering iron against the nut, which melts the thread lock/super glue.
    Just mind your eyes with the fumes!
    It’s very rare that you need to though - Switchcrafts are very robust and don’t tend to fail either. I don’t bother with any other kind of jack, even for cheap guitars - it’s just not worth penny-pinching.
  • ReverendReverend Frets: 5003
    Just a regular switchcraft mono? Best place to get one?
    Any suggestions?
  • sixstringsuppliessixstringsupplies Frets: 429
    every guitar parts shop will stock them. Anywhere between £2.80ish and £4.50
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
  • HenrytwangHenrytwang Frets: 471
    ‘Output’....
    Yes, input at the amp end and output at the guitar end.
    Even though electrons flow equally in both directions.
