Personally I wouldn't remove the LEDs either - they do limit the headroom slightly, but that's intentional and possibly a bad idea to bypass - that would let you push the power IC harder, which they don't always like. If you were going to do that I would probably want to replace the TDA2030 with a TDA2040 or TDA2050 (higher rated).
As has been said already, there’s plenty of instances over the years of people trying to mod them and do speaker swaps and as far as I can see, the conclusion is to just stick with the original as it suits the amp so well.
just play and enjoy!
@icbm would increasing the LED rating give me more headroom without danger of slamming it too hard? I use pretty intense fuzz pedals see
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
When I opened up the amp to take a look at the tank and try to figure out how that could be done, I noticed that a full sized roach had managed to get inside the reverb tank and died there, jamming up the springs in the tank. I managed to remove the roach with some chopsticks and got my reverb working again!
Worth noting for post-Apocalyptic scenarios... the only thing that will kill a cockroach is a Vox amp .
The speaker/cab on the Pathfinder is either a happy accident or genius design, 'cos it does sound remarkably good. It doesn't have quite the rich chime of the Fender but then; that's what you pay the extra 900 quid for.
I have a Mini5 Rhythm, which I experimented with fitting better 8" speakers into than the stock 6.5" one, and none of them even sounded as good. Whether that would still apply if you went from 8" to 10" in the Pathfinder, I don't know.
These amps are worth £100 all day long. I have disabilities, yet I find it manageable to carry it into the local jam session and it holds up with the rest of the band just fine for my purposes.
I think serendipity is the best word I could use to describe it. For a basic amp it stands out against similar solid state amps. I'm not tempted to mod it either.
Sometimes you don’t need a sledgehammer to crack a nut after all.
My recollection of the one I had was that it loved Big Muff type fuzz as well
soundcloud.com/thecolourbox-1
