Hit the Road Jack
HAL9000HAL9000 Frets: 9665
edited June 2019 in Technique
Always played this as || Am : G | F : E ||
However, saw a piano score for this recently which had || Am : Am/G | F7 : E7 || which does actually sound pretty good - on a piano. Strangely this same sequence played on a guitar just sounds wrong to me - especially the F7 which seems to jar.  I’m guessing this is, at least partly, because I’m so used to hearing it the first way (any guitarist I know plays the Am G F E sequence) that anything else feels a bit alien. Also, because the bass notes - and particularly the G - are so dominant that they maybe imply a chord that isn’t actually there.
Ok, I know there’s always more than one way to chord a song but I’d be interested to know how others play this.
Edit - piano example (in Dm but essentially it’s the || Am : Am/G | F7 : E7 || thing transposed)...
https://youtu.be/Q0XVfBjXHPw
Edit 2 - Been playing around with the || Am : Am/G | F7 : E7 || sequence a bit more and found it's all depends on which inversions are used - played as 577555 335555 131241 020130 it really doesn't sound too good. However, both x02210 302010 131211 020100 and x02210 302010 x8786x x7675x are both pretty decent.
  • close2uclose2u Frets: 997
    Am - Am/G - Am/F - E7 works good for me
  • vizviz Frets: 10696
    edited May 2019
    Yes, or
    x0221x
    3x221x
    1x121x
    0x010x (or 02010x). Or if you like jazz, 0x011x
  • TenebrousTenebrous Frets: 1332
    That's how I play it, all starting from the 5th fret Am & working down the D string.
  • guitars4youguitars4you Frets: 14262
    @HAL9000 - interesting as I'd always played it like you - And effectively same as Stray Cat Strut which is starts in Cm - Just thought they were same progression in a different key  - I'm still sure Setzer plays it Cm Bflat Aflat G7 - Interesting to see what you and others say
  • robgilmorobgilmo Frets: 3454
    What is Am/G ?
  • HAL9000HAL9000 Frets: 9665
    edited June 2019
    Am with a G bass (sometimes referred to as Am over G)...
    302210
