So my new Marshall DSL 20 HR arrived from Thomann today.
It was fucked.
Absolutely horrible loud hiss on both channel - that was separate to the regular tube amp hiss you might get at higher volume.
Even worse was the great honking humming noise when engaging the unusable effects loop. Was the same with powered and battery effects. Dreadful noise was as loud as my delay.
QA at the Marshall factory in Vietnam clearly not what it should be. What an utter waste of my time and money. And now I've got to pack it all up and send it back to Germany.
Sorry about the amp. Are you going to get a replacement or has this soured your opinion on it?
I just asked for a refund. I probably won't get another of this model. Don't want to risk it.
It may well just be a bad valve, which could have happened in transit. But also could be something else, if it's been thrown about by the courier - even something simple like a detached jumper connector.
The build quality on the Vietnamese DSLs seems to be noticeably improved compared to the older UK-made ones, but I'm still not sure they're really great. Things like the jumper connectors and the cheap plastic pots don't fill me with enthusiasm.
