Helix or Kemper for bass?
KebabkidKebabkid Frets: 3308
edited May 2019 in Bass
Hi,
I just wondered if any owners of these modellers were using them for bass? I'm more interested in a live capacity rather than *recorded, as by their very nature, I'd imagine they deliver very well in that *scenario.
If so, any standout bass amps or rigs for you?
Thanks
  • fretmeisterfretmeister Frets: 24372
    Helix.
    It's frankly astonishing on bass. No doubt helped by 2 of the lead guys on Helix being bassists themselves.
    Plenty of pro bassists swapping to it - from the Funk / Soul approach of Phil Bynoe to Billy Sheehan at the other end.
  • guitarfishbayguitarfishbay Frets: 7961
    Haven’t tried a Kemper but I think Helix is good on bass
  • sgosdensgosden Frets: 1994
    edited May 2019
    depending how complex you like your signal chain, check out the HX stomp.. Quite a few bassists I've gigged with have moved over to one for their live use now.
    Either going DI , feeding an onstage amp, or a combination of both.
    Super smug* bassist at one gig, rocked up with a single gig bag with bass + stomp in. Then sat with a pint with his feet up whilst guitars and drums struggled in with their gear.
    *intentionally not helping, for the giggles as opposed to just being an arse.
  • MusicwolfMusicwolf Frets: 3659
    I can't help you re live but I’ve often used my Kemper to record bass (I usually take a profiled feed + a DI for processing later).  Having recently acquired a Helix, and inspired by this thread, I tried the Helix on bass last night and it sounded great.
    On guitar I've been favouring Kemper for recording and Helix for live but I think that the Helix may have the edge for bass.  Probably not surprising as I suspect that a lot of commercially recorded tracks use a processed DI'd sound rather than a mic'd bass amp.
  • KebabkidKebabkid Frets: 3308
    Thanks guys and I'm thinking for my first foray into modelling, I might actually go for the Stomp (for guitar and bass) as I can integrate it onto my existing board and use the fx but I also have it there as a back-up and see how it works as a standalone amp unit.
  • FunkfingersFunkfingers Frets: 14463
    sgosden said:
    Super smug* bassist at one gig, rocked up with a single gig bag with bass + stomp in. Then sat with a pint, with his feet up, whilst guitars and drums struggled in with their gear.
    Who does he think he is, the lead singer?
    Quite a few guys on basschat using the Stomp.
    I'm quite tempted as a back up / easy carry version of my Helix rack.
  • digitalscreamdigitalscream Frets: 26628
    The signal routing of the Helix is what helps here - not least because it's trivially easy to have two parallel signals going, which tends to be essential for dirty bass sounds (one clean and one driven). I don't know a huge amount about the Kemper's current capabilities with that, but I'm pretty sure it couldn't handle it internally a couple of years back.
    <space for hire>
  • I'm using an HX Stomp for both bass and guitar. I've used it live with bass very successfully, and tried it out at a studio for the 1st time on the weekend, and it was stupidly easy to get a good tone from.
    edited May 2019
    Out of interest, what bass amp(s) did you use and are you going through FRFRs? In the 'real world', I'm a fan of Aguilar's and Gallien Krueger's and both are modelled in the Helix/Stomp
    The GK is VERY good in the Line 6 stuff.
    It's usually the one I build most patches around. The model of the Aguilar isn't as good to my ears. If I want that warmer low end thump thing then I tend to use the Woody Blue model which is the old Acoustic 360. That is another great model.
    Thanks @fretmeister ;
  • PolarityManPolarityMan Frets: 7293
    The helix is pretty badass on bass, I use a split chain with the SVT models with the highs being gritted up witht he darkglass model.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    A bass?
    A DI box and go stand in the corner and behave
  • Helix is great for bass. I don't like the Kemper for bass.
    Bye!
  • Owner of a Kemper and Helix here. Helix rules for bass no question.
