Advice on fingering
A question I have is when I play triads like the chords at the beginning of Substitute by The Who. I need to barre the high E and B strings at the Fifth Fret and play the 6th fret of the G and strum the strings 4-1. I can't do this comfortably at all using my first finger for the barre and second finger on the G string, its really awkward and uncomfortable and I mute the string below with my second finger so I swap my second finger for my third and I can play it that way no issue. Is it ok do it this way or should I persevere with fingers 1 and 2?
Is it an area that I need to work on or should I not worry about it?
Thanks
Chris
  • SouthpawMarkSouthpawMark Frets: 620
    Make sure you ask permission first.
    10reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    Try barring all 3 strings with your fist finger. This should allow your second finger to come down on the g string in a more upright position, which should help with the accidental muting of adjacent strings.
  • mgawmgaw Frets: 5261
    bending the tip upwards seems to hit the spot
  • revsorgrevsorg Frets: 880
    Wash your hands afterwards, otherwise the fishy smell will linger.
    2reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • martmart Frets: 5205
    I don’t play that intro with any barres at all - for the A chord, I’d use my 1st finger on the B string, my 2nd finger on the E, and 3rd on the G. Same, obviously, for the G chord. That’s just what comes naturally to me.
  • danishbacondanishbacon Frets: 2695
    edited June 2019
    I've just tried what you described, 1st and 2nd finger is indeed a bit awkward. 1st and 3rd no problem. Depends on where it goes next but wouldn't worry about it.
    I think I was at that party...
  • poopotpoopot Frets: 9099
    I've just tried what you described, 1st and 2nd finger is indeed a bit awkward. 1st and 2nd no problem. Depends on where it goes next but wouldn't worry about it.
    Thats called “the shocker”
  • ToneControlToneControl Frets: 11894
    that's what i just tried too, seems the best option
  • I'd suggest persevering with the first finger barre (across all three top strings) and the second for the adjacent fret on the g string. It sounds as if the second finger needs to be a little more arched so as to avoid muting the b string? Having the first finger across all three makes it easier to either mute or let the open d ring with a very slight repositioning. It will also mean less adjustment when shifting to the d triad shape  i.e. switching the second finger from the g to b string without anything else changing.
