Valve rattle - what is it exactly
mattacjonesmattacjones Frets: 506
Hi, I notice what I can only describe as valve rattle. It's in a tweed deluxe which suffers a lot of cab vibration, but is it a valve that can be replaced or is it just unavoidable. All fairly new valves. Cheers
  • ICBMICBM Frets: 72490
    Some valves rattle, some don’t... although most power valves and some rectifiers do at least a bit. They often get worse over time, especially in combos.
    If you can definitely identify which one(s) it is, you could just change those. Hold the valve with a cloth while it’s rattling and you should be able to tell.
  • mattacjonesmattacjones Frets: 506
    Cheers, I'll give it a go using my little ditto Looper. If you don't hear back, I've been electrocuted!
