First amp build - how am I doing?
I've decided to finally build an amp - I've always wanted to and I started on the weekend.
So far I've mounted the components to the main eyelet board and screwed a few things to the chassis.  As I've never done this before would anyone with vastly more experience and know-how be willing to check that I'm not going to fry myself the first time I turn this thing on, please?
Once it's finished I'm thinking about sending it off for a check-over before ever switching it on - it would be nice for whoever tests it out to tell me it's a grand job and nothing needs doing.  I live in hope!
This is the schematic:
https://www.tedweber.com/media/kits/6a14hp_schem.jpg
This is my work thus far - note that I haven't actually soldered much in place yet:
https://imgur.com/a/YhQLPkI
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
  • RiftAmpsRiftAmps Frets: 3173
    edited June 2019 tFB Trader
    Looks like a Princeton Reverb running 6L6s/GZ34.
    PRO TIP: Drill the board to chassis mounting holes before doing anything else and check it all lines up without fouling anything. Don't forget the insulation board underneath! You'll thank me later.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • HaychHaych Frets: 5667
    Thanks @RiftAmps ;
    Yep, that's about the size of it, a higher power Princeton.
    I've been sent a copper cap rectifier - I assume this is a direct swap for an ordinary tube rectifier - I.E I can use a TR if I prefer?
    There's quite a bit of room in the chassis, I've checked that the board fits and I don't think there will be any issue there, although I'm going to find some better mounting screws - the kit came with sheet metal self tapping screws and I just don't see that as practical or robust.
    Haych said:
    Thanks @RiftAmps ;
      Providing you connect up the 2xYellow 5v wires to pins 2 and 8, you can run a valve rectifier. Based on that schematic/PT specs I'd be inclined to only run a GZ34 with 6L6s.
    Rift Amplification
    www.riftamps.co.uk
