Tele body (s/s) with 3 hole bridge mounting?
Most of the tele bodies online I see either have no pre-drilled holes for bridge mounting or with 4 & 6 holes.
Is there a place to get bodies with 3 holes? Or should I just measure and drill my own?
http://www.sporthitech.com/hipshot-stainless-steel-3-compensated-saddle-tele-bridge-3-hole-mounting/ ;
Like this but with 6 saddles
  • SteveRobinsonSteveRobinson Frets: 7032
    I think this is for modern (e.g. US Professional) Telecasters and won't fit a vintage style body. The spacing between the pickup and string-through holes is different.
  • What I should say is I have a body of a tele from gear4music but I'm looking for a replacement body which has a wider control cavity to fit cts pots, which mine doesn't
  • gjonesygjonesy Frets: 146
    can you modify the control cavity? might be cheaper than swapping out the body
  • Im going to look at widening it tonight which would work. It's just this is my first kit and the body has been through a lot of mistakes already!
