The band I'm in currently does it "old school" and want to hear the guitar coming from a backline amp and not from a monitor mix.
It's usually small pubs. I've been using either my Katana 100 or Mesa Express but want to utilise my AX8 more. My usual approach with the AX8 is to have my DXR10 as a wedge in front of me, with a feed to FOH but this wont work for this band.
I guess i could put the DXR10 behind me on a speaker stand to act as backline but what are my other options? I think things like the Atomic CLR or Redsound cabs are probably ideal but too spendy for me.
Id be interested to hear what others have done without breaking the bank.
@simonk - that's an idea, ive got a quilter 101 mini head so i could plug a feed into the effects return on the quilter and then run that through the cab i use for the Mesa.
If i can achieve this through utilising what ive got that'd be the ideal scenario. Thanks for the ideas.
Originally, I had 2 DXR10s pole-mounted either side of the drummer as a backline, being fed from the stereo outs of my Kemper (and AX8 before that).
Now, I'm using two RedSound LS12 cabs instead, which are on the floor (and give more of a guitar cab 'feel'), again on either side of the drummer.
For what you have, just stick the DXR10 on a pole at about chest height behind you. Try a hi cut around 6.5k, low cut around 100Hz.
Having not used the DXR10 as backline, i just wasn't sure it'd work but there's enough real world experience here to suggest it'll be fine.
But I'm not sure wheether they'd be any better than your DXR and it sounds like you've already got hardware coming out of your ears anyway!
I've also heard of people running modellers into the loop of a Katana. I guess you have probably tried that already?
