I'm not one for having the latest phone, preferring to pay £10 to Virgin Media for a Samsung Galaxy J3, but a little while ago the battery started draining a lot quicker than it had been, whether being used or sitting idle as it usually does.
I don't use it that much as I'm near a PC most of the time, and the only non-original app on it is WhatsApp so I can swap photos of my daughter with her mother. I usually have WiFi, Mobile Data, Location etc. turned off.
I suspect that one of the endless updates to something is the source of the problem, as if I switch to aeroplane mode it'll last for ages, suggesting that it's something actively using up the battery rather than the battery not holding a charge.
I've tried a soft reboot and a couple of other things to no avail, and I've ordered a replacement battery from eBay just in case, any suggestions of other things to try ?
"I'll probably be in the bins at Newport Pagnell services." fretmeister
Might give you a clue. Occasionally updates to the operating system can introduce a glitch that rinses the battery, usually one will be along shortly that fixes it if this is the case.
The battery might just be nearing its end of life. All devices sip power if you turn off the networks (aeroplane mode) and use a lot more when they're on so your new battery might solve the problem.
I'll wait for the new battery and see then - I looked for anything that was using a lot of juice and nothing was indicated, which is why I ordered one - only a fiver (which might mean it's not genuine, but fingers crossed) but if the problem goes away I'll know straight away, if nothing changes I'll at least know it's not the battery.
New battery in and charged - it looks to be doing better than the previous one
As far as I can recall, I've never had to buy a replacement battery before which is why I didn't immediately assume that was the problem, that and the problem appearing to have begun suddenly, which made me think it might be a software issue.
You live and learn !
Update: the new battery didn't survive the night before dying, so there's still a problem (this with power saving turned on).
I only ever turn wifi or mobile data on when I need to, and don't have location or anything else I don't need turned on.
My assumption is that it's a recent update to something that's done it, maybe deliberately like they did with the iPhone a while ago? (and maybe still do) so that you end up forced to upgrade = more sales.
Whatever the reason - a curse upon them !
I've forced it to connect to 2G/3G only, if it makes a difference I'll let you know.
As I mentioned, I have exactly the same problem. I tried everything including a factory reset but still no joy, so I took the phone to the Samsung shop on Oxford Street where they have a diagnostic and repair department. They plugged my phone into a computer, pushed a few buttons and stuff and then told me there's nothing wrong with the phone. I told them there obviously is something wrong as it used to last a few days on a full charge and now, all of a sudden, it only lasts a few hours and has to be charged twice a day, even if I don't use it, and that's with a new battery put in it. Their answer to that was "Well, it is over a year old now". I think these phones are probably rubbish, or they just wanted me to buy a new one.
It's probably an update that has deliberately cursed it then, a deliberate ploy to sell more phones. The trouble is they don't realise how stubborn I can be in these situations
Before I went to bed the phone itself said there was enough in the battery to last 23hrs and it lasted less than 12.
Yesterday between 12:45 and 3:45 with power saving off, it went from 100% to 90%
Today between 2:30 and 4:30 with power saving on, but more importantly, with it set to 2G and 3G (auto connect) only, it has gone from 100% to . . . 100% - which is a promising start.
100% @ 2:30pm
97% @ 5:30pm
97% @ 7:30pm
@Winny_Pooh may well have sorted out my problem hopefully it'll work for some of the others in this thread too.
Wikipedia says "4G is the fourth generation of broadband cellular network technology"
I found the following on Virgin Media:
To disable 4G:
I didn't find the WCDMA stuff on my phone, but I did find 2G/3G (auto connect) and tapped that.
Yesterday after 7 hours the charge had dropped from 100% to 75% and the phone was dead this morning.
Today after 7 hours the charge has dropped from 100% to 94% (with power saving on), I'm going to leave it like that overnight and see what state it's in tomorrow, but that's more like the battery drain I'm used to.
I'm assuming it's been spending its time trying to find a 4G connection and failing, trying and failing etc. or something about 4G is freaking it out.
Either way, my phone seems to be back to its old self, but we'll see
Definitely sorted for me - just checked my phone and instead of being totally drained . . . 90% charge.
One last message before I let this drop
2:30pm yesterday 100%
5:30pm today - 86%
The phone has been on the whole time and used intermittently for texting.
So thanks for the suggestions - if anyone wants a battery for a J3 I've almost certainly got a working spare (the replacement is still in for now but might get changed if I get bored and/or curious).
Thanks for that @Paul_C I've set the 2G/3G auto connect, fully charged my phone, left it on overnight and this morning it's reading 98%. Brilliant, that little trick has fixed my phone too.
Thanks again
Steve.
