Warmoth 10-16” Compound Radius and 9.5” pre-cut nuts
jaymenonjaymenon Frets: 834
edited June 2019 in Making & Modding
For a Warmoth 10-16” compound radius, I’m thinking a Graphtech nut with a 9.5” radius would fit fine? (very close to the 10” radius at the headstock end of the board)...
Jay
  • victorludorumvictorludorum Frets: 1025
    Just put a bit of sandpaper on the fretboard and sand the bottom to the right radius. I imagine you would need to just remove a tiny amount.
  • CorvusCorvus Frets: 2929
    Nuts are only really a starting point, each slot should be cut individually as part of proper setup. In terms of actual height difference in the centre of the arc it's tiny, so it should be OK - personally I would always want it properly slotted after fitting, it makes such a difference in a setup.
